transistor help
Discussion in 'General Electronics Chat' started by Robin Mitchell, Feb 28, 2010.
  1. Robin Mitchell
    Oct 25, 2009
    738
    207
    hi everyone, long time no see
    I have a problem...
    if you have a tran and use it as a switch, does a current still go through if there is nothing on the collector but there is a high current on the base?
    Because that is what i am getting with this 639 transistor :(
    thanks
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Schematic please.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Can you post a schematic of what you are talking about?
    Greetings,
    Bertus
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That sounds a lot like a shorted transistor.
    What is the magnitude of the base current?
  5. hobbyist
    Distinguished Member
    Aug 10, 2008
    774
    65
    If it is an NPN transistor, then with no collector resistor, the base emitter junction, acts as a forward biased diode, and all current through the emitter flows out the base, which would upset input signal sources.
    Also if input is large enough then the collector base diode becomes forward biased, and a positive signal out the collector would result, but it would be limited by the current flow through this diode junction.
    This is not normal current flow through the transistor.
    Is this the current flow your talking about.
    If not then like "beenthere" said in the above post, it could be a shorted transistor .
