I want to use a transistor to switch on and off a 6 volt dc motor (7 amps max) using a microcontroller. Thta's it - nice and simple... On and off. Will this transistor do the job? The current ratings are fine, but I am not familiar with all the other stats. Will a microcontroller be able to "turn on" (sorry, don't know the actual term) the transistor, and will it be ok with running 6 volts trhough it?
MJE2955T
http://www.farnell.com/datasheets/64761.pdf
MJE2955T
