transistor gain
Discussion in 'General Electronics Chat' started by vijaytej, Jan 22, 2015.
  1. vijaytej
    Jan 11, 2015
    11
    how can we find the voltage gain of a certain transistor if we are using it as a amplifier.What I mean is to design an amplifier circuit in an accordance with the gain.can you please help........
  2. ErnieM
    Apr 24, 2011
    7,439
    1,627
    A transistor does not have a voltage gain, it has a current gain, and that gain is highly variable depending on the current thru it, the temperature, how this exact transistor was made, the phase of the moon, ect.
    To deal with all that circuits are designed to work with a wide variation in gain, usually above some minimum.
    So the first question is: in what circuit does this transistor reside?
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    In short, the gain of a transistor amplifier depends upon the circuit design.
  4. #12
    Nov 30, 2010
    16,704
    7,351
    Nobody designs a transistor amplifier to run at the gain of the transistor because it will have lots of distortion. You use resistors to force a certain amount of gain for your circuit and expect the transistor to behave nicely because it is not being pushed to its limits.
    cabraham likes this.
  5. shteii01
    Feb 19, 2010
    3,505
    512
    Gain=\frac{Output}{Input}<br />
    Lets see some numbers.
