transistor gain formula
Discussion in 'General Electronics Chat' started by fran1942, Sep 22, 2011.
  1. fran1942
    Jul 26, 2010
    58
    Hello, I understand the gain formula is RC/re+RE.
    My notes say:
    "The term 're' being a transistor parameter which represents the internal resistance of the transistor. The formula for 're' is 26/IC mA. The 26 value is a internal resistance constant used for silicon transistors if you are running at 1mA. If you were running at 2mA you would use 13. In our case we are using 1mA, so we use 26.
    My question is:
    In my case, I am running at 2.5mA, so what value would I use for 're' ?
    Thanks kindly for any help.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    re=26/2.5=10.4Ω
  3. steveb
    Jul 3, 2008
    2,433
    469
    Note that the value of 26 mV is only for room temperature operation. The more general formula is Vt=KT/q, where K is Boltzmann's constant, T is temperature in Kelvin and q is the magnitude of the electron charge. At room temperature T is about 300 K (just at 273 to the temperature in degrees Celsius), so
    V_t={{K\; T}\over{q}}={{(1.38)10^{-23}(300)}\over{(1.6)10^{-19}}}=25.6 {\rm mV}
    Sometimes people multiply another factor in to Vt and use nVt, where n is 1.2 for typical silicon transistors. This brings the value up to 31 mV at room temperature.
