Transistor doesn`t work?
Discussion in 'The Projects Forum' started by Vaarna, Nov 17, 2015.
  1. Vaarna
    Nov 17, 2015
    I have a simple circuit with 2 transistors making an and gate and switches to turn on the transistors and a led to light up when the 2 switches are on, but
    it doesnt work the transistors just heat up.
    ps.sorry if i`m noob
  2. mcgyvr
    Oct 15, 2009
    4,784
    973
    post a schematic..... noob :p
    A schematic will show all the details your words left out.
  3. GopherT
    Nov 23, 2012
    6,297
    4,019
    Post a close-up photo of your circuit and a hand drawn (or better) schematic of the circuit. Also include the value of the resistors you used.
  4. Vaarna
    Nov 17, 2015
  5. GopherT
    Nov 23, 2012
    6,297
    4,019
    Your transistors have been damaged because you should have a resistor between the (+) and base of the transistor. Look at the datasheet for the transistor and look up the max current into the base.
  6. Dodgydave
    Jun 22, 2012
    5,134
    767
    Yes you have omitted the resistors to the Bases of the transistors, so they will burn up, use any values from 1K to 10K.
  7. GopherT
    Nov 23, 2012
    6,297
    4,019
  8. GopherT
    Nov 23, 2012
    6,297
    4,019
  9. mcgyvr
    Oct 15, 2009
    4,784
    973
    Don't even need the transistors just put the 2 switches in series.. (or are the switches momentary..even so)
  10. GopherT
    Nov 23, 2012
    6,297
    4,019
    I think he is experimenting - making an AND logic gate.
  11. Vaarna
    Nov 17, 2015
    yes its a "prototype"
