transistor current
Discussion in 'General Electronics Chat' started by amaresh92, Nov 23, 2010.
  1. amaresh92
    Oct 31, 2010
    23
    consider a transistor connected with emitter resistor and collector resistor.
    when this transistor is subjected to a AC signal, will the current through the emitter and collector resistor will vary as input AC signal varies? variation in AC signal in the sense the direction of flow of current.
    thanks
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Is there a bias or signal on the base of the transistor?
