One last thing Audioguru....
No.
Again the tutor did not read the datasheet. It and nearly EVERY datasheet for little transistors show that for strong saturation then the base current must be 1/10th the collector current (not 1/30th).
In the following video (don't need to start from the begining... you can go to location 5:00 of 7:58):
http://www.youtube.com/watch?v=nqefeNBcowI
I wanted to make sure that I clearly understand this 10 times the collector current idiom.
In the video, when vs is 6V, the transistor is in saturation mode. So for saturation mode, we at least need 5 ma as ic which is the source circuit max current, so are you saying that the max ib required to saturate the transistor is 1/10th of 5 ma which is approximately 500ua?
ib required = beta ((Vs-Vg)/rb)
ib required = 10 ((6-0.7)/100,000)
ib required = 530ua
thanks for your help... really appreciated!
r
No.
ib required = 530ua
r
