You can, but for practical circuits there are many reasons to increase the collector resistor and very few to raise the base resistor.Hello Markd77,
If the LED is too bright, increase the value of the collector resistor.
The reason is that the collector resistor is known and doesn't change much with temperature or current.
In reference to T7... just for my personal information, I can also higher rb to decrease the LED's brightness... right?
No.The tutor in this video actually mentions that the spec sheet of a certain transistor (2n3906 or 2N3904) offers a gain of 60 for a current of approximately 50 ma at Ic. He then goes onto say that if he has 1 ma at the base he can control 60 ma in Ic.
No.So knowing that he needs only about 30 ma in Ic, he supposes that when applying 0.5 ma at ib, it would therefore produce the 30 ma he needs at Ic. But to assure a strong saturation he chooses to provide 1ma for ib.
Yes.rougie said:However, can I simply use it for saturation mode?
LEDs are only for indicators purposes.P.S. Jony130, I have not had a chance to do your circuit yet... but just wondering, why are putting a diode (D1) at the base ... is it for voltage attenuation purposes or just so I can visualize the brightness of the LED based on various RX resistors?
You are welcome.rougie said:Hello Debjit Roy,
That was nicely put and interesting ....
You ain't seen nuthin yet!Hello Audioguru,
wow!, I never would of thought that transistors operating in their linear range are so unstable... Thanks for providing some circuits that show this.
