My apologies in advance for such a simple question. I have a circuit in which I am trying to bias a signal transistor to turn on a power transistor. If the bias current is 100mA is works fine, if the bias current is 20mA it doesn't work (both cases have a voltage of about 2 to 3 volts).
Is there a ratio between base current and collector current that is critical? Is there a signal transistor that will respond to a 10mA bias current? Do I need to use a current amplifier? If there is an appropriate signal transistor please specify the model number same for the current amplifier.
thanks so much
dcd
thanks so much
dcd
