transistor beta
Discussion in 'General Electronics Chat' started by elisettynarendra, Sep 25, 2010.
  1. elisettynarendra
    May 17, 2010
    42
    'ß' beta is the ratio of ic/ib in transistor...does a transistor with higher beta means wether it decreases ib or it grabs more electrons to increase ic ?
    how beta is changed during manufacturing process..providing reference pic ..[​IMG]
  2. Markd77
    Sep 7, 2009
    2,803
    594
    Ib is determined by Vin, Rin and the voltage drop between base and emitter, so if beta changes it has to change Ic (unless the transistor is in saturation).
    The base emitter conection is basically a diode.
    There is a good description of how transistors work if you follow the links at the top.
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    To try and boil this down to simple wording Beta is the current gain a transistor is capable of.
    We'll keep this example as a common emitter configuration since that's the most common.
    If you have a transistor with a Beta of 100 then passing 1 mA through the BE junction should allow the CE junction to pass 100 mA.
    If the Beta is 1000 then that same 1 mA through the BE junction should allow the CE junction to pass 1000 mA.
    Remember, this is just a very simplified explanation.
  4. Ghar
    Mar 8, 2010
    655
    73
    Beta is set by the device geometry and the doping level of the semiconductors... to actually get something out of that sentence you'd need to look into semiconductor physics.
  5. marshallf3
    Jul 26, 2010
    2,358
    201
    It's all done by little elves stomping on silicon stumps.
