Transistor base current
Discussion in 'Homework Help' started by Steve1992, Nov 24, 2011.
  1. Steve1992
    Thread Starter Senior Member
    Apr 7, 2006
    100
    Calculate Ib? Vb?
    The answer given for Ib is 25uA, so the base voltage is 0.8V (33k x Ib).
    But how is 25uA found?
    Hfe is given, but I also need to find Ic?
    Ib is 25uA when Ic is 1mA.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Using
    33k*IB+VBE+(1+HFE)*IB*8.2k=10
    33k*IB+VBE+(41)*IB*8.2k=10
    369.2k*IB=10-VBE
    IB=(10-VBE)/369.2k=9.3/369.2k=25.2uA with VBE=0.7V
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    hfe is defined as the ratio of Ic/Ib.
  4. Steve1992
    Apr 7, 2006
    100
    Thanks t_n_k.
    You multiplied base current by emitter resistor, IB*8k2.
    Is this because IE = IB + IC?
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    That's correct - the voltage drop across the emitter resistance is RE*IE. As to the base voltage VB keep in mind that in this case the base current is flowing from ground potential into the base via the 33kΩ resistor.
    So VB=-25.2uA*33kΩ=-0.83V
