Transistor as modulator
Discussion in 'Electronics Resources' started by baby_1, Dec 19, 2011.
  1. baby_1
    Jun 3, 2011
    39
    Hello friends
    i want to design a FM Transmitter with transistor.i see a lot of circuit that use transistor az modulator.but in university we didn't read anything about transistor aa FM or AM modulator. i want a good reference that explained Transistor az modulator and tell more about it (theory and experimental)
    it because of i read some where that transistor should be in nonlinear mode not linear mode for modulation... i need more and compelete reference
    Thanks a lot
  2. baby_1
    Jun 3, 2011
    39
    No one can't help me?
  3. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
  4. xylon89del
    Dec 28, 2011
    17
    You may want to search for VCO which uses varactor to control the carrier frequency. You can add a buffer at the output of the VCO to prevent loading by the antenna.
    Hope it helps!
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    There are hundreds of FM broadcast band transmitter circuits on the internet and a few AM broadcast band transmitters. Look at them in Google.
    They are modulated by having the modulation change the current which changes the voltage in the oscillator transistor. The FM transmitter oscillator's frequency is changed because its capacitance changes when its voltage changes.
    The AM oscillator's changing current creates AM.
    The transistor oscillators are linear.
