transistor as a switch
Discussion in 'Homework Help' started by gajjarkushan, Nov 29, 2010.
  1. gajjarkushan
    Nov 28, 2010
    actually i wanted to use a transistor a switch so that if i give some voltage to base pin then i can get connection between emitter and collector, so which transistor would work!!!!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Transistors come in more than one flavor, so there is no one way to do this - http://www.allaboutcircuits.com/vol_3/chpt_4/2.html
    Another thing to be careful about is the voltage across the transistor and the current through it.
    Field effect transistors make good switches, too, by the way.
  3. mik3
    Feb 4, 2008
    4,846
    63
    What do you want to switch and what is the control signal?
