Transistor as a switch
Discussion in 'The Projects Forum' started by sportsfan27, Mar 14, 2009.
  1. sportsfan27
    Thread Starter Active Member
    Jan 29, 2009
    43
    Whats the best way to turn a transistor functioning as a switch on and off?
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    NPN or PNP?
    What are the voltages, and load?
  3. sportsfan27
    Jan 29, 2009
    43
    all NPN, voltages range from 10V-250V
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Can you more fully describe what it is that you're trying to accomplish?
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    As a general (very general, lots of exceptions) rule of thumb the emitter is grounded, so the base to emitter current (which turns the transistor on/off) doesn't get involved. The collector/emitter turns on/off, but you have to be carefull it doesn't enter its linear region.
  6. sportsfan27
    Jan 29, 2009
    43
    What I'd like to happen is have a microcontroller turn on the transistors every couple of seconds. The transistors will act as a switch for several LEDs.
  7. mik3
    Feb 4, 2008
    4,846
    63
    Use NPN transistors, with their emitter at ground, a resistor (about 1K) between the base and the microcontroller and your load between the collector and Vcc.
  8. sportsfan27
    Jan 29, 2009
    43
    That's exactly the circuit I have. I don't think I was clear enough, though; my question should have been, how do I program the microcontroller to turn the transistor on and off?
  9. mik3
    Feb 4, 2008
    4,846
    63
    Which microcontroller?
    At what programming language?
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Set the pins you're using to output.
    Set the pin to a logic high (1) to turn the transistor on.
    Waste some time in a delay loop.
    Set the pin to a logic low (0) to turn the transistor off.
    Repeat
  11. mik3
    Feb 4, 2008
    4,846
    63
    I quite disagree with Sgt to waist time in a loop. You can set the particular output to 1, make some other calculations with the uC and then set the output to 0 if desired.
  12. hgmjr
    Jan 28, 2005
    9,030
    214
    Perhaps you would be interested in reading up on the use of a transistor as a switch. The link I have provided takes you to the section on transistors operated as switches. It will provide with some background info so that you will better appreciate the other comments your post has garnered.
    hgmjr
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    While very true, what should the uC be calculating if it's entire function in life is to blink LEDs on and off?
    Getting philosophical, I suppose the uC may be more eager to blink the LED if he also gets to calculate 1000 digits of pi, followed by 1000 digits of e, but in the end, it is all wasting cycles, since the results can't be displayed. Unless the silicological portion of the "id" is somehow boosted, causing the now happy and confident uC to use less power.
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Mik3,
    My suggestion was IAW the "KISS" principle. ;)
    Sure, I could've suggested that our OP utilize an interrupt when timer0 or timer1 overflowed and increment a counter, disabling and re-enabling the interrupt during the service routine, but for this simple exercise such would be rather bewildering for a "n00b".
    As it is, just coding delay loops in assembler can be intimidating.
  15. mik3
    Feb 4, 2008
    4,846
    63
    I have made just a suggestion, don't kill me ;) :p
  16. thatoneguy
    Feb 19, 2009
    6,357
    718
    I can't get Marvin the Paranoid Android out of my head since your post. :eek:
  17. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well then, we'll just have to squash your head. :eek: :D
  18. mik3
    Feb 4, 2008
    4,846
    63
    Who is he?
  19. hgmjr
    Jan 28, 2005
    9,030
    214
    You have not read Douglas Adams I see.
    hgmjr
