Transistor: anode vs cathode
Discussion in 'General Electronics Chat' started by ak_47_boy, Feb 3, 2014.
  1. ak_47_boy
    Jan 29, 2014
    I was wondering. What makes a transistor anode vs a cathode? Since they are symmetrical NPN or PNP shouldn't the anode and cathode be interchangeable on any device? Or collector/emitter i should say...
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    diodes have anodes and cathodes, transistors have a base, emitter and collector.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    They are certainly not symmetrical in structure. The E-B and B-C junctions are very different.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    They haven't been symmetrical since the original Bell Lab transistor...
  5. crutschow
    Mar 14, 2008
    13,496
    3,373
    You can operate a transistor with the collector and emitter interchanged but the beta is typically very low in that configuration due to the asymmetrical structure of the collector and emitter. Also the base-emitter usually has a low breakdown voltage of perhaps 5V or so, thus using the emitter as the collector would limit the maximum allowed collector voltage to less than that value.
  6. Dave_UYZ
    Jan 16, 2014
    29
    It has a lot to do with the direction that the electrons are travelling
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Apparently some of the ancient germanium RF transistors, like the OC44 were more or less symmetrical.
    There are probably a few modern examples, but you invariably get less gain if you swap C/E.
