Transistor and AC
Discussion in 'General Electronics Chat' started by srn, Oct 25, 2011.
  1. srn
    Jan 5, 2011
    Hi everyone,
    As a beginner in electronics I was following the tutorial page at http://www.allaboutcircuits.com/vol_3/chpt_4/5.html about transistor amplifiers and at some point there was an explanation of how AC can pass through a transistor in active mode.
    I understood that if the transistor is not in active mode the negative part of the AC waveform cannot be passed because the transistor is in cutoff then (base-emitter voltage drops bellow 0V). Also in the tutorial there is a simulation showing the signal at output which is a full AC wave.
    How does the negative side of the AC waveform pass in active mode? Shouldn't the output look more like a half wave(positive) AC? I can't imagine how the output voltage could drop bellow 0V if the transistor is forward biased at all times.
    Anyone could please throw some light over this concept please?
    LE:
    I just realized that the output voltage never drops under 0V. I was misreading the simulation graphic. But still, how can the output voltage drop bellow the bias voltage to reproduce the negative part of the input signal?
    Thanks alot
  2. Jony130
    Feb 17, 2009
    3,991
    1,116
