i want to design a transistor amplifier.as seen in the attach ment when output is taken across collector and ground i got a output which is amplified for both cycles and produces a phase shift of 180 degree as it is common emitter.
but when i saw output across emitter and ground i got a output only for positive cycle and not for negative cycle.iam using a bypass capacitor but stil i get a output like this.
