Transistor advice
Discussion in 'General Electronics Chat' started by ajhoward, Nov 24, 2011.
  1. ajhoward
    Nov 16, 2011
    46
    How can I connect a pnp transistor with a switch at its base going to ground, which turns on when the switch is connected to ground which turns off a npn transistor. Then when the switch is open turns off the pnp which turns on the npn.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    What are you trying to accomplish, a complimentary output switch of some sort?
    What are the voltages and currents to be switched?
  3. ajhoward
    Nov 16, 2011
    46
    I am using a reed switch to trigger a monostabe 555 timer, that triggers another astable 555 timer after a set period of time. I need something that when the reed switch open will pull the reset pin of the astable 555 timer to ground to silence the astable timer. I am using a 9V battery for a power source, not sure what the current values are.
    Take a look at what I have so far. Disregard the parts list and the back to front led (just threw that in haven't got that far yet), as I chopped and changed a few things, but I am talking about Q1 & Q2. Q5 is meant to power down part of the circuit after a short delay when the reed switch is opened again.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Since you are already using a relay, use a DPDT relay, so when the relay turns off, it holds the reset until the open switch starts the process over again?
  5. ajhoward
    Nov 16, 2011
    46
    I'm not using the relay in the parts list anymore, I ended up getting the solid state relay A210DN to keep the power consumption down. Thank you for your suggestion.
