Transisor serie ?
Discussion in 'General Electronics Chat' started by FroceMaster, Jan 31, 2016.
  1. FroceMaster
    Jan 28, 2012
    402
    Hi.
    In my Construction i need to know if this is the way to do it or ?
    When IC4 goes high the output should activate all 3 transistors, and the LED's
    When IC3 goes high the output should only activate the T2 and T3 and the LED's
    and When IC2 goes high output should only activate T3 and LED's
    Question is now,
    How many diodes do i need ?
    D1+D2 ?
    D1+D2+D5+D6+D7 ?
    D3+D4+D5+D6+D7 ?
    D3+D4 ?
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    Not near enough info.
    What is IC2, 3, and 4?
    What is the transistor type?
    What power do you have available?
  3. FroceMaster
    Jan 28, 2012
    402
    All is in the png, but cant seem to attach it
  4. crutschow
    Mar 14, 2008
    13,496
    3,373
    The diode gating won't work because of the 0.7V drop across each diode when conducting.
    I suggest using OR gates to do the logic as shown below.
    You can also use 74HCT4075 OR gates if you like. All I had in my library were CD4000 types.
    FroceMaster likes this.
  5. FroceMaster
    Jan 28, 2012
    402
    Or like this ?
  6. ScottWang
    Aug 23, 2012
    4,930
    777
    Are you sure that you want to used the 74HC154 and npn bjt?
    Normally when the 74HC154 has been selected then the output will be low, so the bjt driver should be using pnp.
  7. FroceMaster
    Jan 28, 2012
    402
    i know it's the wrong 74hc154, should be 74hc4514
  8. crutschow
    Mar 14, 2008
    13,496
    3,373
    That will work also.
    But that's an usual symbol for an OR gate. :confused:
  9. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    That's Eagle for you... They used a more typical symbol for the TTL versions. I finally got so tired of looking at them and redrew the symbols.
  10. dl324
    Mar 30, 2015
    3,377
    651
    You could use diodes as long as you don't put multiple in series as in your original schematic and consider maximum current 74HC can source.
  11. bertus
    Administrator
    Apr 5, 2008
    15,800
    2,386
