Transisitor amp
Discussion in 'The Projects Forum' started by esrman66, Dec 29, 2014.
  1. esrman66
    Dec 29, 2014
    18
    I made the amp shown in the transistor biasing video and the voltages Are just about right but the output waveform looks like its amplifying but looks like it has noise or something on it.
    I did use a MPSA06 instead of the 2n2222 he showed.
    Does anyone know how to contact the author of that video?
    Howie
  2. blocco a spirale
    Jun 18, 2008
    1,461
    370
    If you post the schematic and an image of the output waveform I'm sure someone here can help.
  3. esrman66
    Dec 29, 2014
    18
  4. esrman66
    Dec 29, 2014
    18
    How do I do I post an image off my Computer?
    Howie
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    If you have nothing else the "PRT SCN" button captures your entire monitor screen. You can then paste that into MS Paint, crop out the parts of the screen you don't want, save that file and upload it here.
  6. esrman66
    Dec 29, 2014
    18
    Thats what I meant.How to upload off computer to this forum?
  7. GopherT
    Nov 23, 2012
    6,310
    4,031
    When you make a new post on a thread, click the button in the lower right (Upload a File).
  8. GopherT
    Nov 23, 2012
    6,310
    4,031
    If you hold the ALT key before pressing the Prt Scn KEY, Windows will only 'print' (copy) the active window.
    ErnieM likes this.
  9. esrman66
    Dec 29, 2014
    18
    have 3 different inages.
    I can`t load the image here.Seems like it has to be a png file.
  10. GopherT
    Nov 23, 2012
    6,310
    4,031
    Any of the following will work...
  11. esrman66
    Dec 29, 2014
    18
    I converted one to a png and it still didn`t upload
  12. esrman66
    Dec 29, 2014
    18
    Now I get a popup over your reply and can`t close it.
  13. esrman66
    Dec 29, 2014
    18
    I 100_144.png got it!
  14. esrman66
    Dec 29, 2014
    18
    I forgot to tell you that I changed the circuit from one breadboard to a fresh one as the original was way overcrowded with projects.
    Now it doesn`t seem to have any noise but the waveform is not correct.
  15. esrman66
    Dec 29, 2014
    18
  16. esrman66
    Dec 29, 2014
    18
    That one is at just about the design freq.
  17. esrman66
    Dec 29, 2014
    18
    f you notice the images i sent this amp works well into the mghZ range with the stated parts on the schematic.
  18. esrman66
    Dec 29, 2014
    18
    Notice the one at 39MghZ does have some thing that looks like noise or distortion.
    The top traces are the signal at the input of the amp.
  19. blocco a spirale
    Jun 18, 2008
    1,461
    370
    With a 1kHz input and starting at 0V, if you gradually increase the amplitude what happens to the output?
  20. crutschow
    Mar 14, 2008
    13,498
    3,374
    It looks like you are overdriving the amp and it's clipping.
