Transimpedance Amplifier
Discussion in 'Homework Help' started by matth, Jul 31, 2014.
  1. matth
    Jul 31, 2014
    I've been given a task to design three types of transimpedance amp....
    A single transistor amplifier with local feedback - This is where I'm stuck.
    The output value I'm getting from the circuit simulation isn't == Rf x Iin
    My knowledge on amplifiers is extremely narrow, so maybe this is why I'm going wrong... But I have created a common emitter amp, sampling the output feeding it across a resistor and then back into the input.
    Is this incorrect?
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Just for the sake of completeness, there should be a minus sign in front of Rf. Maybe that is the issue.
  3. matth
    Jul 31, 2014
    I wish it was as simple as that, the output is completely different as to what I expected
    Oscilliscope output
    Circuit
    I was under the impression that the oscilloscope should be reading 10kv instead of an offset wave with peak around 2kv and trough -2.7kv
  4. shteii01
    Feb 19, 2010
    3,500
    511
    I think I see the problem. You don't need R1. And, therefore, you probably calculated wrong R2.
    Let me find some links I was reading while I was thinking about your first post.
  5. shteii01
    Feb 19, 2010
    3,500
    511
