Transimpedance amplifier noise issues
Pillow
Joined Aug 5, 2016
Hi everyone,
I'm creating a circuit to measure PPG (blood oxygen saturation) readings using and LED and photodiode, and I'm having some issues with my transimpedance amplifier in the photodiode part. A couple of weeks ago my circuit worked fine, showing a clear difference between the signal voltage from the amplifier when the photodiode was covered and uncovered.
However since last week, when I cover the photodiode, the signal peaks and then quickly returns to the uncovered baseline level. Then, when I uncover it, the opposite happens: the signal peaks briefly in the inverse direction and returns to baseline. I have tried swapping out all the components and wires (except for the photodiode), moving the circuit to a different part of the breadboard, putting a capacitor across the op amp +/- voltage, altering the feedback resistor value, nothing seems to make any difference.
Can anyone offer any advice, or anything I can try? I can post pictures or even a video of the signal changes on an oscilloscope if anyone wants to see it.
Thanks!
bertus
Joined Apr 5, 2008
22,276
Without any information on the parts used and schematic, we can not give you a solution.
Please post a schematic here using the "Upload a File" button.
Bertus
Pillow
Joined Aug 5, 2016
Sorry, I've included a diagram of the transimpedance amplifier:
The op amp I'm using is a TL081CP, the feedback resistor was originally 15.6 M ohms, but I have tried various other values. The photodiode is this one.
