TRANSIMPEDANCE AMP FOR 5nA Signal
Discussion in 'General Electronics Chat' started by longpole001, Sep 18, 2014.
  1. longpole001
    Sep 16, 2014
    29
    Hi guys , i have a need which calls for a photodiode receiving very small signal in 5nA peek current , at about 3uS pulse rate , for bursts of about 100hz . the output would need to drive a A/D on PIC so a 2nd stage amp 100mV peek would be required .
    I have been looking at many TIA designs and the Photodiode i need has 50pf with about 12v bios applied ,
    i was trolling through the site and came across a suggested design . which looks like it may be applied but since i am new to TIA designs and such a low signal value to get from a Photodiode , need some guidance in the TIA and 2nd stage design to get this signal .
    http://forum.allaboutcircuits.com/attachments/photodiode-interface-jpg.38952/
    Regards
    Sheldon
  2. ronv
    Nov 12, 2008
    3,393
    1,449
    Do you have a datasheet or part number for the diode?
  3. longpole001
    Sep 16, 2014
    29
    i have several i am considering but given the very low signal level and limited space for additional optics , a large active area is prefered ,
    to counter the higher capacitance negative bios is likely to need be applied ,
    best one i like so far is S6801-01 , as it has the bandpass filter and a built in lens , and can get down to about 50pf with 10v RV applied , but all have pros and cons for this signal detection
    love an APD , but thats not real cost option
    http://www.osram-os.com/Graphics/XP..., Lead (Pb) Free Product - RoHS Compliant.pdf
    http://www.hamamatsu.com/jp/en/product/category/3100/4001/4103/S6775-01/index.html
    http://www.hamamatsu.com/jp/en/product/category/3100/4001/4103/S6801-01/index.html
    http://www.thorlabs.hk/thorproduct.cfm?partnumber=FDS100
  4. ronv
    Nov 12, 2008
    3,393
    1,449
  5. longpole001
    Sep 16, 2014
    29
    mmm that does look worth a try , i am waiting on the photodiode of my choice , but i have a few with a 1 mm active area , for test on sensitivity of the TIA
    this also caught my eye , as i like the Jfet front end and the lower cost op amp at the output with a good size signal swing , it may suit
    http://www.linear.com/solutions/1785
    found this as well
    http://www.analog.com/designtools/en/photodiode/#/circuitDesign , which looks nice
    http://www.analog.com/designtools/en/photodiode/Share?id=949
    i think noise is going to be areal concern as with this application , i endup puting in 20mv output , on 3us time , using 12v BV , 50pf , on 4.65nA , to see with a low Q value , tool recommend ad8616 , with a 2nd stage
    i know it not 100mV output but i think i can use the quad version of the chip to take it to the next stage of upto larger 100-500mv per pulse for the A/D on the pic
    what your thoughts
    cheers
    sheldon
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
  7. longpole001
    Sep 16, 2014
    29
    ok thanks , it seems that tool link does not have the AD8627 range in the selection option , which i am sure they will fix
    even with best amp it seems ill need to optically amplify this signal a fair 4/1 or more before any amp can make good uses of it without the large amount of noise which is sure to be there
  8. ronv
    Nov 12, 2008
    3,393
    1,449
    Take a look at this IC and the circuit on the first page. The photo diode looks pretty good as well.
    I think this would end up with 200 to 300uv of noise on your 100 mv signal. But that's just the ic and fet.
    It isn't cheap - $9.50.
    http://www.linear.com/product/LT1028
  9. longpole001
    Sep 16, 2014
    29
    "Although the LT1028/LT1128 input stage operates at nearly 1mA of collector current to achieve low voltage noise, input bias current is only 25nA."
    I am wondering if the Jfet reduces the bias current for my very small 5na enough without a lot of noise and signal loss ??????
  10. longpole001
    Sep 16, 2014
    29
    rephase - would the input from the photodiode at 5na be enough to make the jfet conduct to allow the 25na input bios for the amp ?
  11. MrChips
    Oct 2, 2009
    12,624
    3,451
    AD8067 has 0.6pA input bias current.
  12. longpole001
    Sep 16, 2014
    29
    ok ill give it a try
    from the simulations using the tool as base , best i get is about 10-25mV for peek signal of 5nA and about 1.5nA min signal / noise , and will require a further 1 or 2 stages for a signal of about 500mv - 1V , but the noise is likely to be a problem
  13. ronv
    Nov 12, 2008
    3,393
    1,449
    For sure some more input would really help.
    Here is what I have for 100mv output.
    Some things to think about.... The circuit has some DC offset. I don't know what you are doing so don't know if that is a problem or not.
    It is also sensitive to noise on the 15 volt line so for sure this should be a linear power supply.
    Because of the high speed op amps it would just as soon oscillate as amplify so you will need to be careful with the layout.
      File size:
      103.5 KB
      38
      File size:
      114.8 KB
      36
  14. longpole001
    Sep 16, 2014
    29
    thanks for that , yes layout is going to be a big factor in the noise , even when i am breadboard just to see the general response , and its so easy to osc
    the dc offset will be part of the problem as well , which will need to be allowed for
  15. MrChips
    Oct 2, 2009
    12,624
    3,451
    Layout is critical. Use SMT components, solid ground plane on the bottom layer, 0.1uF decoupling capacitors right at the power and ground pins, and a guard ring around the inputs of the opamp (that is, the AD8067).
  16. longpole001
    Sep 16, 2014
    29
    can you simulate a 50pf capacitance on the photodiode and see what you get ? , this looking at using a large surface area
  17. ronv
    Nov 12, 2008
    3,393
    1,449
    That sure wasn't what I expected. It looks better.
      File size:
      102.7 KB
      40
  18. longpole001
    Sep 16, 2014
    29
    wow , thats very interesting , it appear that the additional cap of the diode is allowing the jfet input stage to be behave with a larger swing , a lot more than i would have expected
  19. longpole001
    Sep 16, 2014
    29
    it does add over shoot , but overall it lot cleaner
  20. ronv
    Nov 12, 2008
    3,393
    1,449
    The output is still the same. V=IpdX1meg. But the signal is cleaner. Would you get more current from the larger diode for the same amount of light?
