transient voltage
Discussion in 'General Electronics Chat' started by vks_foe, Aug 18, 2013.
  1. vks_foe
    Thread Starter Active Member
    Jan 11, 2009
    55
    5
    Will there be any voltage spike in secondary windings of a POWER transformer if it is charged on no load (secondary wdgs open ckt)?
  2. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Only if there are any on the primary?
    Max.
  3. vks_foe
    Jan 11, 2009
    55
    5
    i connected a digital multimeter to the 2ndary wdg with 380v o/p at rated input. Input was within limits. The meter blew off. Its range was much higher than 380V
  4. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    I have had occasion to measure many 60Hz transformer secondaries up to 600v 3ph and never seen that happen.
    Only if you have the meter on the Current range. ;)
    Max.
  5. crutschow
    Mar 14, 2008
    13,472
    3,361
    A power transformer will have no spikes on the output when it is open circuit if it is being fed from normal mains voltage.
  6. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    There is some normal Inductance suppression effect by the transformer itself, depending on the frequency of the spike.
    But a power condition meter monitoring brown out conditions, also will show transient spikes that appear, but normally the are minimal, unless high energy equipment with S.S. switching is connected to the same supply.
    Max.
