I want to simulate the transient response of a high frequency (~100 MHz) sine wave when a semiconductor switch (SPDT) changes its output path.
I made a switching circuit in LTspice IV, but it resulted in an ideal response (no transients).
I also tried to make a similar circuit in Simulink, but I couldn't even make it run due to the error:
"Each physical network must be connected to exactly one Solver Configuration block. There is no Solver Configuration block connected to Physical Network with the following blocks: ...". I included the Solver Configuration block in the schematic, but it wouldn't connect to the circuit since it had the wrong connector.
Best regards
-paw
Best regards
-paw
