transformers
Discussion in 'The Projects Forum' started by kumarm, Nov 30, 2013.
  1. kumarm
    Nov 30, 2013
    i am trying to modify an existing tranformer for chargig my inverter batteries
    i got the tranformer from an existing voltage stabilizer with
    input 140-240 volts
    and output as upto 300 volts and 250 watts
    i ripped of the secondary coil ,it has a metal sheet core
    consider there are 50 turns in primary coil (assuming as i dont want to unwind primary also )
    to get 20 volt 15 amp output how many turns should i have in secondary
    the power input in my house is 240 volts and 5 amp
    my inverter battery is 12 volt 42 ah i guess 20 volt and 15 amps will be enough to charge the battery soon enough
    or
    i can i rip the primary too and start the windings from scratch ?
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Put on 10 turns and measure to establish how many turns/volt, a typical number is 2-4T/V.
    Wind the final secondary with gauge sufficient for 15A.
    You have a 240v service that is rated for 5amps only?
    There is no need to rewind the primary.
    If you re-install the metal shield between pri & sec, make sure you do not make contact with each end, as it will produce a shorted turn.
    Max.
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
    I recon 4 or 5 turns will give you 20v if your primary is 50 turns.
  4. kumarm
    Nov 30, 2013
    yes 240 with 5 amps only
    now i can get the volts needed but ampere is still low
    8 turns in secondary 18-19 volt and 7-8 amps only how to increase ampere output
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    If you have a supply (transformer) rated for 1200va (240vx5a) then the secondary current will be inversely proportional, 1200/18 = 66amps.
    The secondary conductor sizing would be be capable of carrying this current.
    Max.
  6. kumarm
    Nov 30, 2013
    can i use single core copper wire instead of waxed coil
    in case of wire will the use of multi core copper wire increase the output in away
    more like using a bunch of copper coil connected parallely instead of 1 thick coil of copper
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    You can used a stranded conductor if you wish, but it is does not make for a compact or neat winding.
    The normal is single strand copper conductor enamel coated, motor winding or magnet wire.
    Max.
  8. kumarm
    Nov 30, 2013
    thank you i got the require output from transformer and battery is charged
    can u guys suggest a simple and easy inverter circuit ...
    sorry if i am asking too much :) i am basically a mechanical engineer so NIL knowledge on electrical circuits but had to do this project to power up my machine with very customized voltage output and i couldnt get it in market
    i need an inverter circuit to get 2 hours of 5amp current at 240 volts from 42ah battery
