Two separate transformers primaries are connected out of phase, they still require correct phasing of the secondaries if summed, either through prior indication of the relevant winding start or by detection.
If series connected, no harm can come of incorrect phasing, if identical windings in parallel, then incorrect phasing must be carried out or short circuit current is a result.
Max.[/QUOT
Or the net voltage obtainable is the same as if onre transformer was used or being used due to being hook up in parallel. Would you agree on that . I dont think it would be zero
Thread starter | Similar threads | Forum | Replies | Date |
Current and transformers | Power Electronics | 9 | ||
Re-using old transformers | Power Electronics | 16 | ||
P | Transformers and Inductors pricing | Power Electronics | 6 | |
Transformers Question | Power Electronics | 10 | ||
K | Multiple Transformers | General Electronics Chat | 8 |
by Jake Hertz
by Aaron Carman
by Aaron Carman
