transformers
Discussion in 'General Electronics Chat' started by dragon24, Jan 6, 2011.
Thread Status:
Not open for further replies.
  1. dragon24
    Dec 23, 2010
    6
    is this fact true, transformers only operate in AC as they require changing magnetic field in their core? thanks
    also if transformers only operate in AC why are sine waves used within mains transformers? thanks:)
  2. Kermit2
    Feb 5, 2010
    3,838
    961
    a small amount of reading would reveal that a SINE WAVE is an AC voltage.
    A changing voltage(and current as well) produce variations of the magnetic field which 'induces' a voltage in the secondary.
    DC makes a constant magnetic flux of one definite magnitude, without change it is unable to 'induce' voltage into anything that is not moving in relation to it.
  3. dragon24
    Dec 23, 2010
    6
    but do DC work within transformers at all? but why sine waves in mains transformers
  4. Kermit2
    Feb 5, 2010
    3,838
    961
    If you actually think about the answer I gave you, you will discover the answer to your question.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
Thread Status:
