I have an old Janitrol furnace that used the old gas valve which opened at approximately 22 Volts. I am up-dating the furnace with a new 24 volt gas valve. My problem is that when I hook up a standard 120 volt to 24 volt step down transformer the transformer is popping, smoking, and shorting out after 120 volts are applied to the primary. This process takes several minutes. I have tried the standard 40 VA transformers. Any suggestions?
