Transformers Question
Discussion in 'Homework Help' started by jegues, Nov 22, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    This is my first attempt at a question of this type so I could be completely off. I've only got one example to follow and it's not exactly the same as this one.
    Anyways, see figure for the problem statement as well as my attempt.
    Am I on the right track? Also, what is the condition to achieve maximum power transfer in a circuit like this?
    Thanks again.
      File size:
      74 KB
      39
  2. Cerkit
    Jan 4, 2009
    275
    Maximum power transfer is achieved when the source and load impedances are matched.
  3. jegues
    Sep 13, 2010
    735
    43
    Is the first portion of my circuit analysis correct as well?
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Do you have 2 Z1s, or is it the writing? I only see Z repeated through the equations and lost track of which one sort of quick.
  5. jegues
    Sep 13, 2010
    735
    43
    There is a Z, Z1, Z2 and Zf. Z1, Z2, and Zf are all defined in terms of Z, I'll then choose Z such that maximum power is transfered but I need to know if I've got the first part right before doing so.
    How's it look?
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Your working looks OK.
