Transformers in series
Discussion in 'General Electronics Chat' started by Vasanthkini, Jul 14, 2010.
  1. Vasanthkini
    Jun 9, 2010
    40
    Hey!
    How about connecting transformers in series.How would it wok and how exactly would i connect them?Any PDF's or documents related to this,would be of vital help.
    Thanks !
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Transformers do have a polarity on the secondary. If you connect them one way the two AC voltages will subtract, while if you connect them the other way the two AC voltage will add. Current will be the lowest rated transformer.
    Vasanthkini likes this.
  3. Vasanthkini
    Jun 9, 2010
    40
    Hey ! How would i find the schematics of both the types of connection you mentioned above?Sadly,google is not answering me (or am i not asking her the right question? )
    :confused:
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    It isn't really a schematic issue. You connect them, them measure the combined voltage. A DVM will tell the tale.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    For two transformers of the same voltage, use a meter to check voltage between one secondary lead (say of transformer #1) and another (of transformer #2). If there is a voltage difference, those secondary leads are out of phase. No voltage difference means they are in phase.
