Transformers and Amperage
Discussion in 'General Electronics Chat' started by roadwaystrybran, Nov 10, 2015.
  1. roadwaystrybran
    May 9, 2015
    8
    Okay, help me out here folks...
    So I get that transformer output is basically just a ratio of primary coil turns by secondary. Pretty simple. But (and here's the kicker) does the amperage do the same thing in reverse? I.e. its inversely proportional to the voltage piece? Or even more simply, no matter what voltage/amperage you get at the output, power remains constant, not counting the power lost by inefficiency of all things? This is probably a scrub question, but thanks in advance.
  2. crutschow
    Mar 14, 2008
    13,466
    3,356
    Yes, neglecting the transformer inefficiency, the power out equals the power in.
    Otherwise it won't be efficient. ;)
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Yep sounds like you got it, power in = power out is a pertty good approximation.
    You do loose a little power from inefficiency.
  4. PackratKing
    Jul 13, 2008
    850
    216
    Amperage in / out, depends on the diameter of the magnet wire, and the cross-section of the core... I have a number of these 40 pounders, that have the large [ #8 ] winding... as a secondary, and several taps off one long secondary, and of course, a normal primary...
    Output amperage on these, is equal to input...
  5. MaxHeadRoom
    Jul 18, 2013
    10,823
    2,495
    Transformers are rated in (K)Va.
    Max.
