what we use a step up transformer ?
why we use step down transformer?
what are their losses ?
Why didn't you look in Google?what we use a step up transformer ?
In a power staton a step up transformer is used to convert the relatively low voltage from the generators to a high voltage (often in the neighborhood of several hundred thousand volts) for transmission to the place it is to be used since, for a given power, a higher voltage means less current and thus less loses in the power line wire resistance and allowing the use of smaller wire. At the end of the line the voltage is stepped down to a lower voltage (perhaps a few thousand volts) for transmission over city power lines to reduce insulation requirements of the wire. Then at the home this voltage is further reduced for safety to the typical 120/240V. All these transformers do have some inefficiency (a few percent) and waste a small amount of the power, but there is still a huge saving in wire cost over not doing the voltage changes.someone told me that step up tranformergive us a low current and also gives some losses after that we use step down transfomer its that true?
Thread starter | Similar threads | Forum | Replies | Date |
Pulse transformer cause short through, coupling capacitor selection | Power Electronics | 0 | ||
Mini-power transformer ? | Power Electronics | 4 | ||
S | DIY low voltage transformer | General Electronics Chat | 26 | |
E | Impedance in a Transformer | Homework Help | 6 | |
E | Flyback Transformer + ZVS Driver + Pulse Capacitor Inquiry | Power Electronics | 18 |
