Noise is produced by something moving, especially if you have say E and I laminations in the core. A solid toroidal core typically makes less noise, but then even the windings may vibrate.
You may try coating the entire transformer in varnish to "glue" things together. There are special grades made just for this, usually the entire assembly is dunked then put in a vacuum bomb chamber.
Thread starter | Similar threads | Forum | Replies | Date |
Pulse transformer cause short through, coupling capacitor selection | Power Electronics | 0 | ||
Mini-power transformer ? | Power Electronics | 4 | ||
S | DIY low voltage transformer | General Electronics Chat | 26 | |
E | Impedance in a Transformer | Homework Help | 6 | |
E | Flyback Transformer + ZVS Driver + Pulse Capacitor Inquiry | Power Electronics | 18 |
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Duane Benson
