Transformer
Discussion in 'Homework Help' started by lemon, Feb 8, 2010.
  1. lemon
    Jan 28, 2010
    125
    A 36Ω resistive load is connected to the secondary of a transformer. The terminal p.d. at the secondary is 24v. If the primary is connected to a 480v a.c. supply, calculate:
    a) the transformer turns ratio
    b) the current and power drawn by the load
    c) the current drawn from the supply
    Relevant equations
    1: V=IR
    2:Vp/Vs=Np/Ns=ip/is
    3: Np:Ns
    P=IV
    Solution:
    a) Is=Vs/R = 24/36=0.667A
    P=0.667Ax24V=16W
    b) Ip=current drawn from the supply
    Ip=Vp/R = 480V/36Ω=13.3A
    Not sure if I'm getting this ok
    Can somebody please check - thank you :)
  2. mik3
    Feb 4, 2008
    4,846
    63
    No, you are not right about the primary's current.
    Use that equatio:
    Np/Ns=Is/Ip or
    Ip=Ps/Vp, since Pp=Ps (ideally)
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    What do you mean by p.d.?
    hgmjr
  4. mik3
    Feb 4, 2008
    4,846
    63
    I guess potential drop even it is not a correct term for this case.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Yeah, I was thinking potential difference but I disdain having to guess what the initials mean when there are multiple possibilities.
    hgmjr
  6. mik3
    Feb 4, 2008
    4,846
    63
    Let's hope the OP will let a drop of lemon on p.d and make its taste better. :p
  7. lemon
    Jan 28, 2010
    125
    sorry. Didn't think that would cause confusion.
    I meant potential difference.
    Should I define things before I use abbreviations?
  8. mik3
    Feb 4, 2008
    4,846
    63
    It should be better unless they are frequenctly used abbreviations.
  9. lemon
    Jan 28, 2010
    125
    Is=24v/36Ω=0.67A
    Ip=Vp/Vs χ Is=0.67A χ 480v/24v = 13.3A
    How can I calculate the number of turns if I don't know either number of turns on one or two?
    Np/Ns=Is/Ip so Ns=Is/Ip x Np
    but no Np:confused:
  10. mik3
    Feb 4, 2008
    4,846
    63
    You do not need to know the actual number of turns but their ration which is Vp/Vs.
    The input and output power is the same ideally.
    Thus,
    Pin=Pout
    Vp*Ip=Vs*Is
    therefore,
    Ip=Vs*Is/Vp
  11. lemon
    Jan 28, 2010
    125
    Hi mik3:
    So the transformer turns ratio is 20:1
    for question b) I want the current and power drawn by the load. So this is Is and Ps.
    Is =Vp*Ip/Vs
    But I don't have the primary current and not sure how to get it from a circuit like this. I would attempt V=IR but there is no primary resistor.:confused:
  12. mik3
    Feb 4, 2008
    4,846
    63
    Np/Ns=100/200=0.5
    Vs=Vp*Ns/Np=6*200/100=12V
    Is=Ps/Vs=24/12=2A
    Pp=Ps=Vp*Ip
    Thus, Ip=Pp/Vp=24/6=4A
  13. lemon
    Jan 28, 2010
    125
    Where did the values for the number of turns come from?
    100 and 200?
  14. lemon
    Jan 28, 2010
    125
    I think you may have taken those values by mistake from one of the other questions you are currently helping me with mik3. My other question on transformers has 100 and 200 turns
  15. mik3
    Feb 4, 2008
    4,846
    63
    You are right, I got confused. :rolleyes:
    The current drawn by the load is Is=Vs/R
  16. lemon
    Jan 28, 2010
    125
    So summary is:
    a)Vp/Vs=Np/Ns=480v/24v=20:1
    b) Is=Vs/R = 24v/36Ω=0.67A
    P=IV, so 0.67A x 24v = 16.08W
    c) Ip=Vs*Is/Vp = 24v*0.67A/480v=0.0335A
    How's that? :D
  17. mik3
    Feb 4, 2008
    4,846
    63
    The answer the is correct because the input power (primary) equals the output power (secondary) and thus Ip has to be less than Is because Vp is greater than Vs.
  18. lemon
    Jan 28, 2010
    125
    The answer the is correct because ???
    Does this mean the answers to the above questions are correct?
  19. mik3
    Feb 4, 2008
    4,846
    63
    Yes, the answers are correct.
  20. lemon
    Jan 28, 2010
    125
    Wow! I can't tell you how good that feels. You've been a rock with all my questions today mik3. Thank you so much.
    Regards
