Transformer
Discussion in 'Homework Help' started by salmanshaheen_88, Jan 3, 2010.
  1. salmanshaheen_88
    Thread Starter Active Member
    Mar 5, 2009
    88
    what is the purpose of air gap in transformer???
  2. djb
    Member
    May 17, 2008
    18
    reducing the magnetic flux between the two coils that are magnetically attached. primary and secondary. This is used to indirectly set the voltage inducted to the secondary coil.
  3. studiot
    Nov 9, 2007
    5,005
    515
    Please don't guess if you don't know the answer, others may believe you.
    The air gap is used if the transformer winding also carries a significant DC current as well as an AC one.
    This is because otherwise the core would become magnetised in one direction by the DC and be less effective for the AC coupling to the secondary.
    The (very small) air gap is essentially non existant to the alternating flux generated by the primary, but blocks the flux generated by the DC.
  4. salmanshaheen_88
    Mar 5, 2009
    88
    so you mean air gap is used for ac saturation, then tell me if my input supply to the transformer is ac then how dc current is generated in the transformer?
  5. JoeJester
    Apr 26, 2005
    3,402
    1,222
    studiot stated: (emphasis mine)
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    The air gap does not "block" any magnetic flux (AC or DC) - it simply increases the total magnetic circuit reluctance.
  7. studiot
    Nov 9, 2007
    5,005
    515
    DC is not 'generated' in the transformer.
    Transformers of themselves don't generate anything. It is all down to what is impressed on the transformer by external means.
    Some applications impress both AC and DC on the primary at the same time for circuit continuity reasons, for example an output transformer in an audio amplifier also carries DC biasing voltages.
    This DC would shift the magnetic operating point in an undesirable manner without the air gap.
    TNK I agree 'blocks' was poor terminology. Sorry
  8. The Electrician
    Oct 9, 2007
    2,300
    335
    What kind of transformer are you referring to?
    A grid frequency (50/60 Hz) transformer? If so, what is the application?
    Or, perhaps, an audio frequency transformer?
    Or a high frequency switcher transformer, such as a flyback transformer?
    Why do you think there is a gap in the transformer (core)?
    Without more information it's difficult to answer your question.
  9. salmanshaheen_88
    Mar 5, 2009
    88
    I was given an assignment to study construction,working,function and operation of transformer. So i just got stuck in AIR GAP
  10. studiot
    Nov 9, 2007
    5,005
    515
    That doesn't answer our questions.
    The Electrician was correct to point out that many if not most transformers do not have an air gap.
    There are also devices called chokes that look a bit like transformers. These are wound on C cores and do posess a gap.
    Where did you get the notion of an air gap?
  11. salmanshaheen_88
    Mar 5, 2009
    88
    while studying my text book, the sentence was " air gap is essential in transformer"
  12. The Electrician
    Oct 9, 2007
    2,300
    335
    What kind of transformer? If it's an ordinary transformer intended for service on a grid frequency (50/60 Hz) source, then very few such transformers have an air gap; it's certainly not "essential" for the vast majority of such transformers.
    There are some that do have a gap, such as a current limited transformer for powering neon tubes, but most 50/60 Hz transformers do not have a gap.
    Can you re-read your text and verify what kind of transformer they are talking about. You might even take a picture of that page in your text, and post it as an attachment.
  13. salmanshaheen_88
    Mar 5, 2009
    88
    the topic is PRINCIPLE OF ACTION OF TRANSFORMER
  14. The Electrician
    Oct 9, 2007
    2,300
    335
    We already knew that you are asking about how transformers work in general. But to help you, we need some more particular information.
    That is why I asked you to do this:
    "Can you re-read your text and verify what kind of transformer they are talking about. You might even take a picture of that page in your text, and post it as an attachment."
    Your reply hasn't done this, so I can't help you any further until you do.
  15. Thevenin's Planet
    Nov 14, 2008
    183
    Don't the air gaps lessen the Eddy currents
  16. studiot
    Nov 9, 2007
    5,005
    515
