Transformer with Capacitive Load
Discussion in 'The Projects Forum' started by HighVoltage!, Oct 29, 2015.
  1. HighVoltage!
    Apr 28, 2014
    95
    I have a fairly simple question:
    If I was to have a shorted cable thats 4/0, shielded cable through the secondary of a transformer...will that be considered a resistive load (Low resistance because of copper conductor) or capacitive load since its a cable?
    The shield is open...only the conductor is shorted.
  2. #12
    Nov 30, 2010
    16,665
    7,310
    It's a resistor.
  3. HighVoltage!
    Apr 28, 2014
    95
    Resistive load you mean?
  4. #12
    Nov 30, 2010
    16,665
    7,310
    Did you wonder if I was talking about a capacitive resistor? As far as I know, they don't exist.
    A resistor makes a resistive load. A resistor does not make a capacitive load or an inductive load unless you get into high frequencies where the shape and length of the wire gets involved with wavelength and parasitic amounts of inductance and capacitance. You said nothing about frequency, so I might still be wrong. Declare this as a gigahertz and all bets are off.
  5. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
    Short circuit secondary that size smacks of a resistance welder!?
    Where does the capacitance come in?
    Max.
  6. crutschow
    Mar 14, 2008
    13,477
    3,362
    You have the low resistance of the shorted cable in parallel with the shield capacitance.
    That effectively shorts the shield capacitance, so the transformer sees only the resistance of the cable.
    HighVoltage! likes this.
  7. #12
    Nov 30, 2010
    16,665
    7,310
    I have some doubts that an un-connected piece of metal is a capacitor of any sort. Did you miss the idea that the shield is not connected to anything or do I need my beliefs adjusted?
    Edit: I'm afraid this discussion will run off into, "certain physical configurations and frequencies". Try to work with me in terms of power line frequencies and power frequency transformers.
