Transformer wiring question
Discussion in 'General Electronics Chat' started by DougB, Nov 14, 2010.
  1. DougB
    Sep 11, 2010
    24
    I have a single single transformer that has 2 sets of inputs and 2 sets of outputs.
    The input connectors/leads are labeled respectively as follows. 0---117v 0---117V.
    The output connectors are labeled respectively as follows.
    0---6v3 0---6v3. Both at 2.5 amps.
    Is there anyway to wire this transformer so that I can get 12.6 volts at 5 amps output
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    When connecting this typical transformer for mains u shud tell us what is ur mains voltage level.
    Secondly this Tx can give u 6.3VAC @ 5A or 12.6VAC @ 2.5A. There is no other way u anyone can configure this to any other isolated output
  3. DougB
    Sep 11, 2010
    24
    Thank you, I expected that would be the result.
