transformer winding
Discussion in 'General Electronics Chat' started by domino1, Nov 15, 2007.
  1. domino1
    Nov 15, 2007
    hi, i am looking for a type of wire to wind a transformer, but can't remember it's name. It has "bell" or "dell" in the name but i just can't remember what it is called. Any ideas anyone?
  2. recca02
    Apr 2, 2007
    1,211
    maybe if u give more information about the ratings of the transformer some of the members here can suggest you one.
    you can also try to google it and see if u find something.
  3. sparkchaser
    Nov 15, 2007
    5
    It is referred to as magnet wire. It is coated to prevent shorting. It comes is different wire gage sizes and as recca02 indicates you would need to know the application in order to determine the proper wire gage.
  4. GS3
    Sep 21, 2007
    408
    35
  5. sparkchaser
    Nov 15, 2007
    5
    The type of wire you should use also depends on the frequency of the circuit that uses the transformer.
    Litz wire is typically only used up to a few MHz.
