I recently made my own coil bobbin on a lathe using a plastic rod.
At the ends of the bobbin I drilled small holes to fish the wire through.
My problem is that the wire is 34 AWG so it's very fragile. I have had to completely unwind and rewind the coil once already because the wire broke right at the hole. What can I do to solve this problem?
I was thinking of getting some really small screws, threading them into the bobbin ends and then soldering the wires to the screws?
Does anyone have any suggestions or recommendations?
Thanks in advance
Thanks in advance
