Transformer secondary
Discussion in 'Homework Help' started by bwd111, Aug 15, 2013.
  1. bwd111
    Jul 24, 2013
    117
    Also could some one go over this calc and why I got this answer wrong as well. 120 v ac primary and turns ration of 5:1 what is secondary voltage. my answer is 600 vac. I multiplied the primary voltage by the turns ratio
    120*5 = 600 v ac
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Vp : Vs :: Np : Ns
    Because the primary has 5 turns for each turn of the secondary it is a step-down transformer.
    120 : x :: 5 : 1
    Read this as, 120 is to x as 5 is to 1
    In the above ratio and proportion statement x must be 24.
    screen1988 and bwd111 like this.
  3. LDC3
    Apr 27, 2013
    920
    160
    Start at the beginning and state the relation between voltage and number of turns on the primary and secondary so I can see how you did your calculations.
  4. bwd111
    Jul 24, 2013
    117
    I forgot to divide both sides by 5 120/5=24 V AC
  5. jegues
    Sep 13, 2010
    735
    43
    \frac{120}{x} = \frac{5}{1}
    \Rightarrow x = \frac{120*1}{5} = 24
    screen1988, JoeJester and Papabravo like this.
