transformer replacement; problem with legs
Discussion in 'General Electronics Chat' started by sadiq3210, Jun 14, 2013.
  1. sadiq3210
    Jun 14, 2013
    26
    I have a device whose transformer is broken.
    This transformer has 6 legs; 3 on each side.
    Now i want to replace it.
    I took a similar transformer from a mobile charger.
    This transformer has also 6 legs but 4 legs on one side and 2 on other side.
    So, i can not connect it directly.
    Now i want to connect the transformer by using wires.
    Can you please tell me, where i connect each leg?
    If you want more information, you can ask.
    i attached a picture; the transformers look like that
  2. Dodgydave
    Jun 22, 2012
    5,159
    772
    You need to know the voltages of the transformer before you can swap it.
  3. gerty
    Aug 30, 2007
    1,154
    304
    No picture shown.. Are you using all six connections on the old transformer
  4. sadiq3210
    Jun 14, 2013
    26
  5. sadiq3210
    Jun 14, 2013
    26
    how can i tell you the voltages of transformer?
    there is no details written on transformer.
  6. sadiq3210
    Jun 14, 2013
    26
    for convenience, i made this. you can tell which leg in trtansformer A correspond to which leg in transformer B
  7. Ramussons
    May 3, 2013
    562
    92
    What is this device? Can you post some photographs? Of both the component side and the pattern side? At least we may get some clue.
    Ramesh
    absf likes this.
  8. sadiq3210
    Jun 14, 2013
    26
    the device is a hair trimmer. i has two batteries of 1.2 V connected in series, it means a total of 2.4V.
    see the pics
  9. PackratKing
    Jul 13, 2008
    850
    216
    Additionally, you will have to identify which leads are the Primary / secondary. Using wire beyond that leaves you with the issue of how to mount it in your equipment.
    It seems no two transformers are ever wound the same, unless you are into production of one item that only needs one design...
  10. Ramussons
    May 3, 2013
    562
    92
    Ok, that confirms that it's not a 50 Hz transformer but a a SMPS trasformer which will have a Primary, Secondary and a feedback winding.
    No, you cannot use the transformer from a mobile charger.
    A mobile charger also has a SMPS transformer with similar windings, BUT different Terminals, No of Turns, Polarity of windings.
    And the mobile transformer is wound for a 5 Volt output, you need 3 Volts.
    May be you can try for a replacement from the manufacturer. Else, you can do a rewind of the Mobile charger transformer with the same windings as the original and hope that it works.
    Ramesh
  11. szhighstar
    Jun 26, 2012
    27
    5
    can you advise schematic of transformer?
  12. sadiq3210
    Jun 14, 2013
    26
    guyz. Is ramussons right?
  13. sadiq3210
    Jun 14, 2013
    26
    i can't. i m not an electrical engineer .
  14. absf
    Dec 29, 2010
    1,493
    374
    Yes, I believe he is right :D
    Allen
  15. sadiq3210
    Jun 14, 2013
    26
    now i want to join the broken transformer. i found the 3 terminals but where are the remaining three?
  16. PackratKing
    Jul 13, 2008
    850
    216
    If the equipment in question is old / used enough to break down in this manner, I would opt to simply replace the equipment with new, and cut my losses.
    Repairing transformers is an art, with very few artists :D
  17. sadiq3210
    Jun 14, 2013
    26
    i want to make a new transformer. i broke the outer structure of broken transformer and i took the coil.
    then i started to open the winding, i unwraped a long wire and after that it finished.
    then i removed a green layer of plastic between the two winding.
    then i started to unwrap the inner winding. during unwraping the inner winding, i see that either the wire broke or it might be already cut and it was made up of two pieces of wire. I am not sure about that.
    then i unwraped it completely. now i have three pieces of wires. i'll tell u the length of these soon
    what you have to do is to tell me how to make new winding
  18. Ramussons
    May 3, 2013
    562
    92
    Now we know that the outer winding was the Secondary (output)
    Inside the Green Plastic layer, the Primary with a Feedback winding.
    I hope you noted down:
    The Coil Termination Lug Number,
    The Number of Turns,
    The Direction of Turns
    Ramesh
  19. sadiq3210
    Jun 14, 2013
    26
    no,t the same didn't.
    but i think that all the windings are wound at the same direction.
  20. Ramussons
    May 3, 2013
    562
    92
    We'll need to know the
    Number of Turns
    AND the
    Terminal numbers.
    An attempt can then be made to duplicate the transformer on another core.
    Ramesh
