Q1. How do you calculate transformer ratios if the primary and secondary have a difference in wire diameter?
Q2. Does it makes sense to use the inductance ratios of the primary and secondary?
Q3. If you are replacing your primary with a thick wire, and you want the ratios of the transformer to remain the same, would it work if the thick replacement wire has the same inductance as the previous primary (with respect the the secondary wire being the same size as the original primary wire) ?
Thanks.
Thanks.
