Transformer question
Discussion in 'General Electronics Chat' started by rcullens, Jan 9, 2014.
  1. rcullens
    Apr 26, 2008
    15
    Hell all,
    I pulled a mini transformer out of a circuit and looking at the schematic it has two legs on one side and three on the other. But the physical transformer itself has two legs on one side and four on the other. Can anyone tell me why that is?
    huang likes this.
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Possibly to allow two secondary (or primary) windings to be connected in series or parallel.
  3. rcullens
    Apr 26, 2008
    15
    Ok so how do I tell which one the schematic used? Also the "unused" fourth lead was soldered in the PCB but im not sure what it was going to.
  4. #12
    Nov 30, 2010
    16,685
    7,324
    By looking at the circuit board. There is no unused lead. Somewhere, two of the legs were connected together to make a center tapped secondary.
  5. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Agreed. PREM and others make transformers with split primaries and secondaries so that various combinations of input/output can be handled. It sounds like your secondaries were stacked to make a center tapped transformer.
    BTW: PREM makes great stuff. First mfr. to come to mind.
    huang likes this.
  6. huang
    Jan 8, 2014
    10
    help u to mark this thread ask some other engineer help u,sorry i am not engineer here,
  7. rcullens
    Apr 26, 2008
    15
    Ok so which leg would i use? the schematic shows 3 and the transformer has 4?
  8. #12
    Nov 30, 2010
    16,685
    7,324
    Look at the circuit board and see which 2 pins were connected to each other. If you can't do that, you will have to give the primary some AC current and measure the secondary windings to find their ends and their phase relationship.
  9. rcullens
    Apr 26, 2008
    15
    could I ohm it if i put it back in the circuit? or check voltage across it with power applied?
  10. #12
    Nov 30, 2010
    16,685
    7,324
    Ohms will do nothing for you. Voltage measurement is the only way.
  11. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Can you post the schematic, showing the transformer connections?
