Transformer question
Discussion in 'General Electronics Chat' started by ruleworld, May 3, 2009.
  1. ruleworld
    Jun 9, 2006
    22
    is it possible to connect 220v at two ends of a autotransformer that have only one coil and use 22v from two terminals from inside points without having a common terminal? like showed on the diagram. will it be safe? thanks.
      File size:
      8.8 KB
      21
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Autotransformers aren't safe by themselves, because they don't provide isolation from the mains.
    If you want to use an autotransformer, you'll also need to use an isolation transformer.
  3. ruleworld
    Jun 9, 2006
    22
    its not that safe but can it be used in that way?
  4. Bernard
    Aug 7, 2008
    4,240
    414
    Yes. Do I recomend it, only if I know capabilities of person. Electric clothes dryers are safe as long as they are in good repair and back cover is in place.
