Transformer question
Discussion in 'The Projects Forum' started by sportsfan27, Feb 11, 2009.
  1. sportsfan27
    Thread Starter Active Member
    Jan 29, 2009
    43
    I've got a schematic with a transformer in it, and there are a some numbers next to the wires leading into and out of the transformer. What do these numbers mean?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Can you give us another clue?
    John
  3. kubeek
    Sep 20, 2005
    4,689
    806
    Probably numbering of wires on the physical transformer, or winding ratios.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Be a bit easier to tell with the numbers to see.
  5. sportsfan27
    Jan 29, 2009
    43
    This is what it looks like
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Those are terminal numbers.
  7. sportsfan27
    Jan 29, 2009
    43
    What does that mean?
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Terminal numbers are the numbers assigned to the wires coming out of the transformer, and the terminals they are soldered to.
  9. sportsfan27
    Jan 29, 2009
    43
    So it doesn't say anything about the winding ratios?
  10. kubeek
    Sep 20, 2005
    4,689
    806
    No it doesn´t. Maybe the rest of the circuit can help with that.
  11. sportsfan27
    Jan 29, 2009
    43
    Something else that came to mind: what does it mean if a transformer says 30-0-30V on it?
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It means that the secondary is center tapped, with an output of 60 VAC. That doesn't say anything about current, though.
  13. virtualeast
    Jan 13, 2009
    If you can find a Part Number or Model Number for the Transformer, you can look up the specs or technical data for it.
  14. ketanstar
    Feb 17, 2009
    i want to use step down transformer for 230 v ac supply.so what factors should i consider?
