transformer question
Discussion in 'Homework Help' started by Kgaidzanwa, Jul 23, 2005.
  1. Kgaidzanwa
    Jul 23, 2005
    A 100kva transformer has iron losses of 650 W and copper losses of 960 W when operating on full-load. Calculate the transformer efficiency when suppling
    1 50% full-load at 0.8 power factor
    2 25% full-load at 0.5 power factor
  2. haditya
    Jan 19, 2004
    220
    efficency can be calculated using the foll formula
    η = x.KVA.cos Φ /(x.KVA.cos Φ +x^2. Cu losses+Fe losses)
    x=current/full load current..
    =0.5 in the 1st case
    =0.25 in the 2nd case
    cos Φ =power factor
  3. Kgaidzanwa
    Jul 23, 2005
  4. Kgaidzanwa
    Jul 23, 2005
    Thanks for input but i am failing to substitute for x if you can show me your working it will help me understand the topic
