Transformer problems
Discussion in 'General Electronics Chat' started by david1or2, Jul 13, 2005.
  1. david1or2
    Jul 13, 2005
    I have a Fender Twin Reverb,the output tranny has a problem,the two wires going to the speaker jack are green and black,when I put a volt/ohm meter on these two wires there is no resistance.
    I put the red lead of the meter on the green wire and the black lead on the black wire with the meter set on ohms and it reads .000 ohms.
    Can anyone tell me the problem and how to fix it without replacing the transformer?
  2. CATV
    Member
    Apr 17, 2007
    11
    There is probably nothing wrong with this transformer.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What led you to suspect the transformer? Unless your meter is pretty good, it may not be reporting the winding resistance, which may be less than an ohm. Have you checked your speaker's voice coil?
  4. nomurphy
    Aug 8, 2005
    567
    12
    The output xformer is for impedance matching, so you should get a reading of at few ohms on the secondary/speaker side. Make sure the xformer wires are not connected to anything when taking the measurement.
    Also, disconnect the speaker and try measuring it to see if you get 4-8 ohms. If there is more than one speaker, disconnect them and measure individually.
    If the xformer is bad, or a speaker, there's nothing you can do except replace it.
