Transformer nitpicking
Discussion in 'Off-Topic' started by Ratch, Dec 19, 2008.
  1. Ratch
    Mar 20, 2007
    1,068
    magikal,
    You have not defined the question very well. A solenoid is not used to couple with another solenoid in order to transform a voltage/current. It is used to move a plunger in order do some physical work. A transformer has no moving parts, and forms an inductive storage system that transforms voltage/current.
    Next, what are you asking? Are you inquiring about driving the transformer higher than its design frequency? The voltage will then decrease due to parasitic effects as enumerated by the responders above. Otherwise within its design frequency, the voltage will not change much.
    Think of it this way. Suppose dI/dt is 10 amps/1 sec for a value of 10 . A doubling of the frequency will decrease the time to 1/2 sec so that dI/dt = 10/(1/2) = 20 . Doubling of the frequency will also double the inductive reactance of the transformer. That in turn will halve the current so that dI/dt = 5/(1/2) = 10 , which is what we had before. So it balances out until the frequency becomes so high that secondary effects take over.
    Ratch
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    At the risk of being even MORE hopelessly pedantic, you're WRONG! :) A solenoid is, by definition, the coil of wire. In its conventional use, it is indeed used as the mechanical device you describe. But all the basic electronics literature speaks of the inductance of a solenoid as the form itself.
    http://en.wikipedia.org/wiki/Solenoid
    See also, the RCA Radiotron Handbook, for a historic perspective.
    Now you know!
    Eric
  3. triggernum5
    May 4, 2008
    216
    And knowing is half the battle.. Go Joe!
  4. Ratch
    Mar 20, 2007
    1,068
    KL7AJ,
    No, I am not wrong. We are both right. You should read the link you presented, especially the second paragraph. You are presenting the definition in terms of physics, as described in the first paragraph. Whereas I was thinking about the second paragraph which defines it from an engineering viewpoint. Whichever way you define it, the important thing is that a transformer is NOT described as two mutually coupled solenoids. http://en.wikipedia.org/wiki/Transformer
    But did you?
    Here is an interesting story. Several years ago I went to a GM auto dealership to purchase a replacement for my broken electric door lock. The parts man kept insisting that is was a "motor" even though it most certainly was a solenoid. It was listed in his parts catalog as a motor, and the fact that it did not have a commutator could not dissuade him.
    triggernum5,
    Knowing what, specifically?
    Ratch
  5. KL7AJ
    Nov 4, 2008
    2,043
    292
    I believe in England, electromagnets are often referred to as electric motors.
    So.....how would you describe concentric solenoids with lots of mutual inductance....such as the "Loose Coupler' of crystal radio yore? Or any link-coupled R.F. circuit for that matter? Other than the fact that there's no iron core, they are still transformers. And solenoids.
    Of course, there are transformers that are NOT solenoids, as well. Toroidal wound transmission line transformers, for example. Or parallel-line hybrids. Or even your garden variety directional coupler.
    And if you REALLY want to be pedantic, a 1:1 transformer can't really be called a transformer, because it neither transforms current NOR voltage. All it does is transform dollar bills from your wallet into copper and iron.
    Ahhh....now where were we? :D
    Eric
  6. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Using the term 'solenoid' for the coils on a transformer is just fine and correct.
  7. Ratch
    Mar 20, 2007
    1,068
    KL7AJ,
    Even when it doesn't have a commutator? So the flippers of a pinball machine are "motorized?"
    So you are going to call every inductive system within a part or appliance a solenoid? See discussion below.
    According to your link, "the term solenoid refers to a loop of wire". So by that reasoning, just about any transformer can be termed a "solenoid".
    Yes, it can. It transforms the input into an isolated output, so is therefore useful.
    Discussion: So if every loop of wire is a solenoid, why even have the word? You cannot make any practical inductive component without looping the wire one way or another. It is a matter of semantics, but I would not call a coil of wire that is closely bound to another coil of wire, as in a transformer, a solenoid. My definition of a solenoid would be an inductance that operates in relative isolation from any other inductance. If two inductances work together, then they should be called a transformer, or coupler, or whatever. But not solenoids.
    We were explaining to the OP why the output voltage of a transformer becomes less at higher frequencies. I believe I summed it up previously.
    BillO
    Not if you consider a solenoid to be a independent inductance from an engineering viewpoint.
    Ratch
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Physician, heal thyself.
  9. Ratch
    Mar 20, 2007
    1,068
    thingmaker3,
    I am not a physician and have nothing to heal.
    Ratch
