transformer/ IM
Discussion in 'General Electronics Chat' started by eagle55, Mar 23, 2010.
  1. eagle55
    Mar 9, 2010
    6
    we know, transformer is sort of static induction motor. in no-load condition starting a power transformer draw 7-times more current like IM?:confused:
  2. rjenkins
    Nov 6, 2005
    1,015
    69
    The only time an unloaded transformer takes excess power is if the supply is turned on part way through the mains cycle.
    If the power is applied from the start of the cycle (as the voltage passes through zero) there is no surge.
  3. The Electrician
    Oct 9, 2007
    2,300
    335
    You've got it just exactly wrong. The maximum transient (surge) occurs when you apply the voltage as the sine wave is passing through zero. No surge occurs when the voltage is applied at the peak of the sine wave (assuming the transformer inductance has no resistive component; otherwise the timing for minimum surge is slightly off of the peak).
